I'm trying to edit and extend a dp. After changing and adding some dpe I will save my work. The editor don't save it but give me a "critical message":
WCCOAui (1), 2018.09.21 15:02:55.156, IMPL, SEVERE, 52,
Unexpected state, PersDpIdentification,
handleManipTypeChangeMsg, changeType unmoeglich, type container
returned 2
Did anyone have an idea what happen there?
KR
Marc
Error changing DP
- rglock
Re: Error changing DP
this could be the case, when you are using type-references and you want to modify a referenced type (this should be done at the source type directly).
best regards
Rainer
best regards
Rainer
- marc.jaegeler
Hello Rainer,
thanks for your fast response.
On Friday the error happen directly while editing an internal type. Today it was possible to edit an internal type but the dp which is referencing to the internal dp doesn't take the changes.
kr
Marc
kr
Marc
- rglock
seems to be a bug...
We'll continue this discussion/topic over your newly create service request.
best regards
Rainer
best regards
Rainer
