Hello.
I try connecting to remote host to 4999 port for remote management of managers (WEB format of console window).
But browser returned error: ERR_CONNECTION_REFUSED.
I used pmon_query function for getting statuses of remote hosts, but function returned error: tcpOpen, timeout expired.
Firewall on hosts not using, ping command is good.
Code:
int port = 4999;
string host = "s2012a";
dyn_dyn_string ddsResult;
pmon_query("##MGRLIST:STATI", host, port, ddsResult, false, true);
DebugN(ddsResult);
WCCOAui (1), 2018.09.17 14:31:40.551, CTRL, WARNING, 54, Unexpected state,
Module: _QuickTest_
Panel: C:\\WinCC_OA_Proj\\ARM\\panels\\test.xml [test.xml]
Object: 4 named: "Fire" of type: PUSH_BUTTON
Script: Clicked
Library: C:\\WinCC_OA_Proj\\ARM\\scripts\\libs\\pmon.ctl
Line: 268, tcpOpen, timeout expired
Connection to remote ip to 4999 port failed
- adaneau
Re: Connection to remote ip to 4999 port failed
If you are not localhost, by default you cannot access pmon via TCP.
See
qthelp://wincc_oa/doc/Notes/Note-40.htm
Alexandre DANEAU
See
Alexandre DANEAU
- v.yarymov
ohh..WinCC is a pain and suffering
Do You know, maybe there are other things that can see info from remote managers?
- adaneau
I mean, you can change this but you need to add some whitelist
look at link from help
- v.yarymov
Sorry.. I cannot find this documentation. I very small time working with WinCC and dont know about much things.. Where I can see it?
I try find something about tcpOpen in WinCC OA Online Help, but not finded needed information.
- adaneau
Section title is:
IP access lists for TCP server sockets
Alexandre
Alexandre
For details why accessing the Process Monitor from a remote machine is blocked please have a look at the following Forum thread
https://portal.etm.at/index.php?option= ... 27&id=1598
In the thread you can also find information for the configuration of the Process Monitor.
- v.yarymov
Thank Alexandre, and thank Leopold.
I added in config files
[pmon]
localAddress = ""
Yes, all working. Also need looking on firewall sometimes
[pmon]
localAddress = ""
