NFedorenko
How to change alert class in alert_hdl config using dpSet()?
Post
by NFedorenko »
Hello to all!
I got some problem with new patch, such as my old code doesn't work.
I need to change alert class in _alert_hdl of dpe in ctrl script.
To get current alert class (AC) i use dpGet():
anytype c;
dpGet(DPS + ":_alert_hdl.._class",c);
DebugN(c);
The result is:
System1:BAC0_. (Type: 0 Sys: 55 Dp: 48140 El: 1 : 0..0)
To set new AC I used
dpSet(DPS + ":_alert_hdl.2._class",COMBO_BOX1.text())
COMBO_BOX1.text() value is "System1:S7_AC"
But it doesn't work now.
So how to change alert class in alert_hdl config using dpSet()?
Please help =)
Re: How to change alert class in alert_hdl config using dpSet()?
Post
by leoknipp »
Maybe the problem is the missing "." at the end of the datapoint name for the alert class datapoint.
NFedorenko
Post
by NFedorenko »
Ah!
That's true!
Thank you, Leopold!
