forwarding of variadic arguments in CONTROL
christian.kotz@siemens.com
Post by christian.kotz@siemens.com »
has anybody found a way to forward variadic arguments to another CONTROL function also taking variadic arguments:
The following code is syntactically OK, but does not yield the expected result: :(
Example
`sprint` as a function (no error handling here for simplicity)
string strFormat(string format, ...)
   va_list parameters;
   string result;
   va_start(parameters);    // possibly not needed
   sprintf(result, format, parameters);
   va_end(parameters);      // possibly not needed
   return result;
How is it done correctly? Where can I find more information on variadic arguments in CONTROL than in the help file?
I am using Win CC OA 3.12
Christian
schneebergera
Re: forwarding of variadic arguments in CONTROL
Post by schneebergera »
It isn't possible to pass "var-args" to built-in CTRL functions [sprintf () is a built-in CTRL function] - this is not implemented.
But it works to pass "var-args" to other USER-defined (self-written) CTRL functions.
best regards,
