Hi there,
I would like to delete a config of dpe by script (e.g. the _alert_hdl config), not the value of the config but the config itself. Is there any function to do this?
I did not find any clue in the help.
Cheers,
Sebastien
delete dpe config
Re: delete dpe config
If you want to delete a config you can do a dpSet() on the _type attribute with the value 0.
In case of an _alert_hdl config you possibly have to acknowledge pending alerts first and then you have to deactivate it before it can be deleted.
- sblancha
ok thanks for help.
Sebastien
Sebastien
Perhaps it is better to use the constant 'DPCONFIG_NONE' instead of the value 0.
Even if the value of this constant does not change, searching on the constant name will probably return less result than a search on the value 0.
