Cannot manage to transfer configs from a masterdatapoint to its DPEs.
Natty
Post by Natty »
I developed a WinCC OA (v3.14 - P05) application for the Montparnasse Paris train station. Attached files are the WinCC OA server logs.
I do not manage to transfer configs "_alert_hdl" and "_address" from a masterdatapoint to its DPEs. All the "alert_hdl" configs do appear underneath DPEs. But some DPEs heritate from an activated "alert_hdl" config when other heritate from a deactivated one. "address" configs can't be seen underneath DPE leaf. I have added severeal datapoints last few days and I didn't have this problem.
Log file show :
2018.09.06 09:02:43.143["error==-5 in dpCopy from _mp_HAOT_PT to _mp_Test111.pt"]
WCCOAui (10), 2018.09.06 10:12:19.119, CTRL, SEVERE, 5/ctrl, Location of the following log entry:
Module: Para_61
Panel: C:\\Siemens\\Automation\\WinCC_OA\\3.14\\panels\\para.pnl []
Object: 10 named: "activeX" of type: DP_TREE
Script: OnDpTypeChanged
Library: C:\\Siemens\\Automation\\WinCC_OA\\3.14\\scripts\\libs\\mp.ctl
Line: 1292
WCCOAui (10), 2018.09.06 10:12:19.119, PARAM,SEVERE, 105, Invalid license, DP: System1:_mp_Test111.dsfs.Etat:_address.._type, MAN: (SYS: 1 Event -num 0 CONN: 2)
WCCOAui (10), 2018.09.06 10:12:19.119, CTRL, WARNING, 5/ctrl, Location of the following log entry:
Module: Para_61
Line: 1295
WCCOAui (10), 2018.09.06 10:12:19.119, SYS, WARNING, 0, , Error setting config (1), System1:_mp_Test111.dsfs.Commande:_address.._type, 16
Module: Para_61
Line: 1295
WCCOAui (10), 2018.09.06 10:12:19.119, SYS, WARNING, 0, , Error setting config (2), System1:_mp_Test111.dsfs.Commande:_address.._reference, M.1.16.0
Do you know how to solve this problem ? I can send screenshots of the tree if needed.
Thanks in advance.
https://www.winccoa.com/fileadmin/image ... 180906.zip
log_20180906.zip
(3.86 MiB) Downloaded 224 times
Re: Cannot manage to transfer configs from a masterdatapoint to its DPEs.
You possibly get the log message for the invalid license because you have reached the maximum number of IOs in your project. Activating additional _address configs is not possible in that case.
The limit for the IOs is defined with the license you are using in this project.
Natty
Post by Natty »
Ok. Do you know how I can check the number of IOs used ?
Thank you very much.
Regards
You can use the I/O counter panel (Lab --> Prototypes) to get the number of active addresses.
https://portal.etm.at/index.php?option= ... &Itemid=79
Natty
Post by Natty »
Thanks you. One last question, I am using redundant servers and I have a 15 000 IOs license. Does it mean I can only use 7 500 DPE (with an activated address) on each server ?
No, in a redundant system you can use the number of I/Os defined in the license.
The database is the same on both servers and every server counts therefore the complete number of I/Os.
