Plant Model Import Warning
emaddocks
Post by emaddocks »
Hi All,
I've been trying to do a simple import of a plant model with a single view and a single node underneath it but I keep getting the following error on import:
doAsciiIn returned warning code: 79
I even get this error when importing the exact same file i've just exported. I haven't been able to determine what this error code 79 is as it's not listed in the help file.
Does anyone have a step by step guide on exporting and importing the plant model and what is required to do it?
Cheers
Eric
Re: Plant Model Import Warning
When doing the ASCII import with the ASCII manager panel two logfiles WCCOAascii*.log are created.
Maybe you can find additional information for the error in one of these two files.
emaddocks
Post by emaddocks »
Great thanks Leopold. I knew it would be a simple matter of finding the right checkbox to select.
The WCCOAascii_info.log indicated that my View already existed so it skipped creation. I just had to select the 'Automatically update existing DP types' on import. I hadn't selected this as it didn't sound relative to plant model imports.
Thanks for your quick response!
Cheers
Eric
