Is there a way to get the overall number of dpe for a running project?
Cheers,
Sebastien
Get number of dpe
- adaneau
Re: Get number of dpe
Yes this is quite easy to achieve:
- Use any dpGetAll (description or alias) function and count the lenght of result . As any DPE is having a common, this makes the trick:
dyn_string ret, desc;
dpGetAllDescriptions(ret, desc);
DebugN(dynlen(ret));
- However, you may want only a list of DPE containing a value, then just go to sysmgm / Diagnostics / Event manager connections . Click on event table and go to 3rd tab, every project information relative to DPconfig from event are here (_original amount is amount of DPE having a value).
Alexandre
Alexandre
You can also get the number of configs with the debug flag "-report configmanager".
The debug gflag can be used for every manager which holds configs during runtime (Data-Manager, Event-Manager, Drivers).
When using the panel for the Event Manager Connections you probably have to set an update interval in the panel to get the actual values.
- Ulrich Ahrens
Is it possible to use dpconnect (or query) to respond to the addition or removal of a data point to a particular type of data point? For example, to determine how many data points of a particular data point type exist?
When using WinCC OA 3.16 you can use the new function sysConnect() to get the information when a datapoint is created or deleted.
To get the number of datapoints for a specific type you can use dpNames() with filters.
