I'm using OLE DB from CTRL Script (via CtrlADO) and getting error randomly that prevents the script to get correct data from a SQL Server 2017 DB.
The script need to be running H24 and getting data from different SQL Server DBs.
The error number is -2147217871 and error text : HYT00.
I have looked on google, it could be a low timeout issue.
How could I change this timeout setting?
Or maybe it is due to something else?
Any help would be very much appreciated.
Regards.
Error with OLE DB requests
Re: Error with OLE DB requests
To keep the connection alive you could execute a sql statement after some time of inactivity.
- uxout
Hello !
In fact, I don't want to keep the connection alive.
Everytime a request needs to be done, there is a connection opening, request and close.
For the moment, my only clue is that I might add some index to boost the requests.
- adaneau
I was reading that ADO is limiting the answer time to 30s for reply to a query. Does yours takes more?
https://stackoverflow.com/questions/175 ... ry-timeout
https://docs.microsoft.com/en-us/sql/ad ... erver-2017
I think you can set it up at the connection like said in this post but cannot guarantee...
@Gertjan: I havent seen any way to set custom answer time in WinCC OA, is it possible?
Alex
Alex
Currently there is no option to set connection options, like this query timeout. The only way to set options is in the connection string or with a statement after the connection is established.
You could file a feature request to extend the current functionality with a possibility to set options.
