Max. Clients
juma4
Max. Clients
Post by juma4 »
Hello together
How many clients can operate WinCC OA at the same time?
Markus
adaneau
Re: Max. Clients
Post by adaneau »
If I remember properly, like any manager you can run up to 256 UI simultaneously. However I wouldnt recommend it ;)
Re: Max. Clients
From a technical point of view the maximum number of UI clients which can be connected to one system is 255 (manager number 1 up to 255).
When talking about UI clients all different clients are counted as UI client: Standard UI, Desktop-UI, Mobile UI, ULC UX.
How many clients can be connected and operated in one system in real plant operation (beside the allowed number of UI clients defined by the WinCC OA license) depends on
-- the used hardware (RAM, CPU)
-- the "size" of the project
-- the amount of messages/value changes which need to be processed in the system and/or to the UI managers
juma4
Re: Max. Clients
Post by juma4 »
Thank you for your fast Help.
Markus
