Hello Forum,
I would like to draw my own shape ( for example google style Tabs ) from Polygons by using a bezier curve. The reason for this is that i don't have to worry that much on how the arc is drawn.
If i look at the 'xml' file of the shape i see that a bezier curve has two types of 'point' properties in the 'pointarray'
- x y
- i
With the 'points' property of shape in script-code the "location" points can be set.
Q: Which property do i need to use to define the "CurveIdx" point from script-code?
Hope someone can help me.
Michel Eijgermans.
Howto create a bezier curve in polygon from control-script
- michel.eijgermans
Re: Howto create a bezier curve in polygon from control-script
Currently you can't. It's not implemented
- michel.eijgermans
Hi Martin,
Thanks for the answer.
It would be a nice addition to a polygon-shape to have a property 'curveIndexes' just like the 'points' which returns or sets a dyn_int with index-numbers.
Can this be added to a roadmap?
Michel.
Michel.
