I have a two screen system setup from a custom template I have created.
One of the buttons in the navi panel is configured to run the following control script when clicked:
LogoutDialog(true,3,"vision/login.pnl","");
When I click on the button in the first screen's navi panel it shows the "are you sure you want to log off?" message with 'close all modules' checked, but only the panels on the first screen are closed when I click OK. If I do the same from the same button on the 2nd screen's navi panel, the panels on both screens are closed.
Any ideas why?
Logout dialog
Re: Logout dialog
You could add some debug statements in the logoutDialog/loginDialog function to discover the cause.
- mhargreaves
Re: Logout dialog
I think i have found the problem in panel.ctl
if ( (closeModules == 1) || (closeModules == 3) )
for (i = 1; i
for (i = 1; i
- innovis
Re: Logout dialog
This is a feature
No, seriously, if you are using more than one monitor I recommend you to take care yourself of closing modules.
