Control: Comparing equal mappings yields unexpected result
ChristianGoehring
Post by ChristianGoehring »
I stumbled upon a unexpected behaviour in Control when comparing mapping objects. Consider the following code:
  const mapping m1 = makeMapping("x", makeMapping("y", true), "a", "b");
  const mapping m2 = makeMapping("x", makeMapping("y", true), "a", "b");
  DebugTN(m1 == m2);
This outputs "TRUE" on the log as expected. But the following code:
  mapping m2 = makeMapping("x", makeMapping("y", true));
  m2["a"] = "b";
  DebugTN(m1 == m2);
outputs "FALSE on the command line even though the mappings are the same in terms of keys and values. You can verify this via output on the log. If you compare with casting it to string before, it works:
  mapping m3 = makeMapping("x", makeMapping("y", true));
  m3["a"] = "b";
  DebugTN(m1, m2, m3);
  DebugTN("(m1 == m2)="+(m1 == m2));
  DebugTN("(m2 == m3)="+(m2 == m3));
  DebugTN("(m1 == m3)="+(m1 == m3));
  DebugTN("((string)m1 == (string)m2)="+((string)m1 == (string)m2));
  DebugTN("((string)m2 == (string)m3)="+((string)m2 == (string)m3));
  DebugTN("((string)m1 == (string)m3)="+((string)m1 == (string)m3));
This outputs on my machine (3.15 P010 Win7)
WCCOActrl4:2018.07.19 13:20:05.451[mapping 2 items
WCCOActrl4: "x" : mapping 1 items
WCCOActrl4: "y" : TRUE
WCCOActrl4: "a" : "b"
WCCOActrl4:][mapping 2 items
WCCOActrl4:]
WCCOActrl4:2018.07.19 13:20:05.451["(m1 == m2)=TRUE"]
WCCOActrl4:2018.07.19 13:20:05.451["(m2 == m3)=FALSE"]
WCCOActrl4:2018.07.19 13:20:05.451["(m1 == m3)=FALSE"]
WCCOActrl4:2018.07.19 13:20:05.451["((string)m1 == (string)m2)=TRUE"]
WCCOActrl4:2018.07.19 13:20:05.451["((string)m2 == (string)m3)=TRUE"]
WCCOActrl4:2018.07.19 13:20:05.451["((string)m1 == (string)m3)=TRUE"]
I am acutally expecting the comparison between the same mappings to be true - am I missing something? Maybe there is a mappingCmp method but I did not see anything like this ...
Re: Control: Comparing equal mappings yields unexpected result
The reason is: When you assign a value to a key which is not in the mapping yet, a new entry is being created before the assignment then puts the value at that key, but the new empty entry gets initially a "mixed" datatype,
which is different than what happens when you create a mapping directly via makeMapping().
