Hi Team,
I am trying to convert value coming from the periphery in (mm) to be read/ stored in the db in (m).
I am using the _msg_Con base curve config
Is this the right config?
If the config is alright the second question is When i try to write the value manually (original value) in para the conversion is not reflected in the online value
Is this a normal behavior?
Bader.
Converting periphery hfloat value
Re: Converting periphery hfloat value
If you want to do a conversion for values received the periphery you can use the config _msg_conv.
The conversion is made within the driver before the value is send to the Event Manager when receiving a value from the periphery.
Therefore it does not work when you are setting the value in the para module.
