Closing event scripting
uxout
Post by uxout »
I want to close properly all my sockets before the complete shutdown of a CTRL manager.
Is there a way to add a script to react on the shutdown of a CTRL manager?
adaneau
Re: Closing event scripting
Post by adaneau »
Hi Manh Thang
in 3,16 you have sysConnect()
"exitRequested"
This event is triggered the first time a CTRL manager is requested to exit, e.g. either by losing the connection to the event manager or by a stop request from pmon (e.g. project shutdown) or a SIGTERM signal.
Exiting is done in the following steps:
stop all running scripts (threads/CTRL-modules)
start "exitRequested" event callback threads
disconnect everything (e.g. dpConnect, query connects, alertConnect, sysConnect)
When the last thread started for the exitRequest event will stop, the manager stops as well. Be careful that the started threads will not take too long, since on a project shutdown pmon will kill the CTRL manager when it does not terminate in the defined number of seconds (set via console panel). When a second exit request happens while the "exit requested" threads are still running, the manager will terminate immediately without starting any threads again.
The callback will get the exit code (int) as argument.
I guess it will makes what you want :)
uxout
Post by uxout »
Oh great ! That's what I'm looking for, thank you.
How can I do it with WinCC OA prior to 3.16?
The 'sysConnect' is a new 3.16 feature, so there is no real solution for a control manager.
As a workaround you could use the close/terminate event of a panel in a silent UI.
A Ui in silent mode is designed for printing a panel without the need to open the panel in a runtime UI.
It is not designed to execute runtime tasks, e.g. tasks which are normally done in a CTRL manager.
