Issue in WinccOA database power config \"Description\" import / Export
SenthilMurugesan
Post by SenthilMurugesan »
Hi Team,
In WinccOA database power config "Description" export is working fine V3 format.
But when importing back with changes it's not importing, please see the log msg.
Senthil M
SenthilMurugesan
Re: Issue in WinccOA database power config \"Description\" import / Export
Sorry miss the log file in below mail, Please find it https://www.winccoa.com/fileadmin/image ... ascii1.zip
wccoaascii1.zip
(4.54 KiB) Downloaded 212 times
It looks like you have double quotes in the file and therefore the import is not possible.
LANG:10010 ""U1_AVR_A""
Normally it should like LANG:10010 "U1_AVR_A".
SenthilMurugesan
Hi Leopold,
I thought the format was correct but I look like not, thanks for correcting me.
Moreover I analysis why format changed, I found that when I modify the description in excel and save the changes in excel and open the same file on notepad. I saw those double quotes format change, I don't know why.
Later I closed the notepad file and re-open the same in excel, I didn't see those double quotes in excel for the langstring.
We are doing import/export from our own using ascii command, not using Xls_powerconfig Mapara add-in. Excel is used to modification only power config variables, Please suggest me how to remove the double quotes from the ascii file.
When I export the file from WinccOA database Description Power config .
lt:3 LANG:10010 "Start Push Button" LANG:10001 "Start Push Button" LANG:10027 "Start Push Button"
When I open the file in excel and Save with changes "Start Push Button" to "Start Button" and open it in notepad, It changes automatically as show below.
"lt:3 LANG:10010 ""Start Button"" LANG:10001 ""Start Button"" LANG:10027 ""Start Button"" "
When I import back with ascii manager, I'm seeing those error. Can you suggest why its happening.
Thanks,
adaneau
Post by adaneau »
Those double quote adding is due to excel... nothing can be done for that in WinCC OA...
