Sharing data from a distributed system through OPC
nmnogueira
Post by nmnogueira »
Hi all,
I have a distributed system consisting of two redundant systems, and I need to make all the data available to an outside server.
My questions:
  • Is it possible to share the data from System1 and System2 through the OPC server of System1?
  • It it possible to install an interface server, running a Remote OPC server driver which will make the data from both systems available to be read?
Thank you!
Re: Sharing data from a distributed system through OPC
A WinCC OA process can only connect to one system at the time.
It is possible to share data for distributed systems using a WinCC OA OPC server.
If it can be used in your project depends on the WinCC OA version and which OPC server (OPC DA, OPC A&E, OPC UA, OPC HDA) you are using.
Please give more detailed information (WinCC OA version, OPC server).
