Hi All,
I plan to implement something and I would like to have your opinion: for my trend I have different Ref values/lines that I would like to see represented on the grid. I can see that it is possible to define a ref value for the grid and also the spacing below/above which is going to set the number of grid lines that are shown above/below the reference value .
But on my specific case the grid lines that I want to represent do not follow a constant distance from the ref value. For example assuming the ref value is 500, I want to represent the following grid lines:450(90%refvalue), 300(60%refvalue), 150(30%refvalue)
Any ideas?
Thanks in advance.
Antonio
Grid Trend - Ref value
- fmulder
Re: Grid Trend - Ref value
You could add 3 extra lines to your trend. You do not connect these lines to a datapoint but instead fill them via scripting.
Or,
* Make some extra lines
* Add code to the 'scroll' event of the trend widget
* In the scroll event-> Use scripting to add fake values to your lines
Hope this helps
share the fun
Frenk Mulder
Or,
Hope this helps
share the fun
Frenk Mulder
- AMRPatricio
Hi Frenk,
thanks for reply.
"You could add 3 extra lines to your trend. You do not connect these lines to a datapoint but instead fill them via scripting.", I guess you meant "curves" not lines?
I want to represent grid lines, which represent thresholds from my curve.
Thanks,
Antonio
thanks for reply.
Thanks,
Antonio
- fmulder
So... ?
Just make 3 fake lines and call them 'grid1', 'grid2' and 'grid3'.
Instead of connecting them to a datapoint YOU add the points to the lines by scripting.
Use "curveMarking" to define extra reference lines (as many as you like) per curve.
- AMRPatricio
Hi Martin,
thank you for your idea but "curveMarking" only allow me to create one single line per curve(or a range), not multiple single lines.
Antonio
Antonio
You are wrong.
Try the following example code:
this.curveMarking("#1_2", 1, 100, 100, "red", "[dashed,oneColor,JoinMiter,CapButt,0]");
this.curveMarking("#1_2", 2, 120, 120, "red", "[dashed,oneColor,JoinMiter,CapButt,0]");
this.curveMarking("#1_2", 3, 160, 160, "red", "[dashed,oneColor,JoinMiter,CapButt,0]");
- AMRPatricio
Thanks for your help Martin .
