SEVERE error is appear.
interelec
Post by interelec »
Hi
When I open the project, Some SEVERE error is appear. I use the wincc OA 3.16
Bolow is log file. Please give me a tip. I don`t know is error.
I am waiting for your answer.
Thank you.
WCCILdata (0), 2018.06.19 11:31:35.126, IMPL, SEVERE, 54, Unexpected state, AlertHistory, commitUpdate, Alert not in datasets nor in living DB
System1:_Conn_event_0_1_to_event_0_2.Link0:_alert_hdl.._state (Type: 209 Sys: 1 Dp: 296 El: 2 : _alert_hdl.._state)
WCCILdata (0), 2018.06.19 11:31:35.127, IMPL, SEVERE, 54, Unexpected state, AlertHistory, commitUpdate, Alert not in datasets nor in living DB-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
WCCOAvalarch (0), 2018.06.19 11:31:35.998, IMPL, SEVERE, 54, Unexpected state, DPE not present (ErrNum=4), ErrorDP: DpId = 139, elementId = 4, Archive::processWrite - DPE does not exist in this SetFile, trying to add it, [D:\\workspaces\\3.15\\workspace\\Exe\\DataNew\\ValueArchive\\Archive.cpp:2559]
WCCILpmon (1), 2018.06.19 11:31:36.065, SYS, INFO, 1, Manager Start, C:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOActrl.exe -PROJ KTX_WK_PJT_SAT_34th -pmonIndex 11 webclient_http.ctl
WCCOAvalarch (0), 2018.06.19 11:31:36.084, IMPL, SEVERE, 54, Unexpected state, DPE not present (ErrNum=4), ErrorDP: DpId = 139, elementId = 24, Archive::processWrite - DPE does not exist in this SetFile, trying to add it, [D:\\workspaces\\3.15\\workspace\\Exe\\DataNew\\ValueArchive\\Archive.cpp:2559]
WCCOActrl (0), 2018.06.19 11:31:36.127, SYS, INFO, 1, Manager Start, PROJ, KTX_WK_PJT_SAT_34th, V 3.15 - 3.15 platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOActrl (0), 2018.06.19 11:31:36.129, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
Re: SEVERE error is appear.
For the analysis we need the complete logfiles to be able to see what happened before and after the log messages occured.
Therefore please get in contact with your common WinCC OA support. To your support request please add the log files pmon. and PVSS_II.log. If it is a redundant system the files for both servers are needed.
