Use some Alarm Text in one DPE
zabortxu
Post by zabortxu »
Hi everybody,
I need to visualized any alarm text that I get from some DPE, in another DPE, using a data point fuction. It's that possible? This DPE are from same Data point type.
Thank you
Re: Use some Alarm Text in one DPE
With a datapoint function you can set the original value for the dp element where the dp function is configured. Setting the alert textes is not possible with a dp function.
Please take into account that you need to set the _alert_hdl config inactive if you want to change the alert textes. Therefore you cannot modify the text for an already existing alert.
