How to Connect AES Panel to RDB?
AngusETM
Post by AngusETM »
Hi all,
We are running an RDB database and need to connect the default AES screen to this database. We've looked through the AES screen and can't find anywhere to set up the connection to tell the screen which database to look at. How can this be achieved?
Thanks in advance.
Kind regards,
Angus Heyworth
Re: How to Connect AES Panel to RDB?
Which database is used is defined in the config file.
The AEScreen is using these settings to determine how to read historical data.
When using RDB you can define if data shall be read directly from the database (queryRDBdirect = 1) or via the Data Manager (queryRDBdirect = 0).
