Subprojects
- mhargreaves
Subprojects
If a subproject is registered to a project, can the main project use datapoint types & datapoints from the subproject? I have tried it and can't see any of my subproject's datapoints in the para when running the main project - is there something special I need to do?
Re: Subprojects
The Data manager is only loading the database located in the main project. There is no possibility to load several databases.
The sub projects are used for files not related to the database, e.g. panels, scripts, config files, ...
Therefore a sub project normally does not have a db directory.
