Vertical Text
mcmullan
Vertical Text
Post by mcmullan »
How can I create a text field on a panel that displays the text vertically...e.g.
M
y
T
E
X
T
instead of the normal...
MyText
I now that you can rotate the text field but that is not what is needed.
Re: Vertical Text
You can't rotate a Textfield!
If you don't use it as Input you can use a "TEXT_EDIT" (multiline Textfield)
and append every char as new line
main(mapping event)
 shape target = getShape("TEXT_EDIT3");
 formatString(target, "Hello World");
void formatString(shape target, string input)
  int temp;
  for (int i = 0; i < strlen(input); i++)
    temp = i;
   target.append(strwalk(input, temp));
