Few days ago project on one server in redundant system crashed and it was not able to restart whole day. Whole time this message was written in log:
So this means that server was trying to start, but could not do it. What could be the reason for this? Project on the other server worked normally whole time. I tried to completely stop the project and than to start it, but I kept getting the same error message. The problem disappeared when I restarted the server. Is it possible that some process in background blocked project from starting or what?WCCILpmon (1), 2018.05.27 09:50:07.787, SYS, SEVERE, 10/pmon, The central server manager WCCILdata(0) stopped! Restarting the project
WCCILpmon (1), 2018.05.27 09:50:07.887, SYS, INFO, 14/pmon, Completely stopped the project - restarting it
This is the whole pmon.log from the moment when crash happened.
Also, next morning I tried to start Arhive Manager 0 on the other server in this system and the project also crashed, writing the same error message in log, but now it was able to restart normally.WCCILpmon (1), 2018.05.27 09:35:44.456, SYS, INFO, 11/pmon, Detected stopped manager WCCOActrl(110) - restarting it #1
WCCILpmon (1), 2018.05.27 09:35:44.524, SYS, INFO, 1, Manager Start, /opt/WinCC_OA/3.14/bin/WCCOActrl -PROJ TakovoPreljina -pmonIndex 47 asterisk.ctl -num 110
WCCILpmon (1), 2018.05.27 09:49:28.184, SYS, INFO, 22/pmon, Got RESTART_ALL command from WCCILevent, restarting the project
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(4) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(144) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(142) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(141) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(140) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(138) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(3) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOAsnmp(16) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.285, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(34) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(133) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(125) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(119) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(118) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(117) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(116) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(114) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(113) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(112) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(111) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.286, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(110) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(108) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(107) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(102) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(101) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(100) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(33) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(31) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(30) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(25) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(24) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(22) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(21) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(20) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.287, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(14) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAsnmp(15) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(12) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(11) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(10) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(9) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(7) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(5) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(4) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(6) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(2) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(1) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAmod(3) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAui(1) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCILdist(1) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOActrl(2) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 17/pmon, Stopping Manager WCCOAvalarch(5) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:49:28.288, SYS, INFO, 118, Last error already repeated 50 times. Until another output occurs, this one will be blocked.
WCCILpmon (1), 2018.05.27 09:50:05.531, SYS, INFO, 17/pmon, Stopping Manager WCCILproxy(1) with signal SIGTERM
WCCILpmon (1), 2018.05.27 09:50:05.619, SYS, INFO, 119, Last error repeated 74 times.
WCCILpmon (1), 2018.05.27 09:50:05.619, SYS, INFO, 14/pmon, Completely stopped the project - restarting it
WCCILpmon (1), 2018.05.27 09:50:05.720, SYS, INFO, 1, Manager Start, /opt/WinCC_OA/3.14/bin/WCCILdata -PROJ TakovoPreljina -pmonIndex 1
WCCILpmon (1), 2018.05.27 09:50:07.988, SYS, INFO, 1, Manager Start, /opt/WinCC_OA/3.14/bin/WCCILdata -PROJ TakovoPreljina -pmonIndex 1
WCCILpmon (1), 2018.05.27 09:50:10.009, SYS, SEVERE, 10/pmon, The central server manager WCCILdata(0) stopped! Restarting the project
WCCILpmon (1), 2018.05.27 09:50:10.109, SYS, INFO, 14/pmon, Completely stopped the project - restarting it
WCCILpmon (1), 2018.05.27 09:50:10.129, SYS, INFO, 1, Manager Start, /opt/WinCC_OA/3.14/bin/WCCILdata -PROJ TakovoPreljina -pmonIndex 1
WCCILpmon (1), 2018.05.27 09:50:12.153, SYS, SEVERE, 10/pmon, The central server manager WCCILdata(0) stopped! Restarting the project
WCCILpmon (1), 2018.05.27 09:50:12.254, SYS, INFO, 14/pmon, Completely stopped the project - restarting it
WCCILpmon (1), 2018.05.27 09:50:12.354, SYS, INFO, 1, Manager Start, /opt/WinCC_OA/3.14/bin/WCCILdata -PROJ TakovoPreljina -pmonIndex 1
WCCILpmon (1), 2018.05.27 09:50:14.380, SYS, SEVERE, 10/pmon, The central server manager WCCILdata(0) stopped! Restarting the project
WCCILpmon (1), 2018.05.27 09:50:14.480, SYS, INFO, 14/pmon, Completely stopped the project - restarting it
Nedžad
