create a discrete alarm in script
tmalone
Post by tmalone »
I can see a number of examples of creating a continuous alarm in script, but I can't seem to find a good example of creating a discrete alarm in scripting.
I tried to follow the para panel, but... WOW, that is a path to confusion.
What confg property contains the continuous vs. discrete vs. multiinstance?
I want to build a button that creates the alarm for S7Plus connection issues:
State.ConnState
0=inactive
1=disconnected
2=connecting
3=connected
4=disconnecting
5=failure
Perfect for a discrete alarm!
tmalone
Re: create a discrete alarm in script
Post by tmalone »
I found an example for discrete alert handling for boolean values.
the example for creating a discrete alarm is in the help->Module PARA->_alert_hdl->alert handling of discrete values-> at the bottom.
For non-bool discrete values, is the DPDETAIL_RANGETYPE_MATCH still the way to specify discrete alarms???
Yes, the example is actually for non-bool values. It is a workaround to get a discrete alert handling on boolean values, because in the para it cannot be configured.
tmalone
Post by tmalone »
Here is a clean example:
void addCondAlert(string dpeName)
dyn_float limits;
dyn_string alerttext;
dyn_string alertclass;
int rc;
dyn_errClass err;
limits=makeDynString("*","2","3","4");
alerttext=makeDynString("", "Warning", "Fault", "Unavailable");
alertclass=makeDynString("", "warning.", "alert.", "information.");
rc = dpSetTimedWait(0, dpeName + ":_alert_hdl.._type", DPCONFIG_ALERT_NONBINARYSIGNAL,
dpeName + ":_alert_hdl.1._type", DPDETAIL_RANGETYPE_MATCH,
dpeName + ":_alert_hdl.2._type", DPDETAIL_RANGETYPE_MATCH,
dpeName + ":_alert_hdl.3._type", DPDETAIL_RANGETYPE_MATCH,
dpeName + ":_alert_hdl.4._type", DPDETAIL_RANGETYPE_MATCH,
dpeName + ":_alert_hdl.1._text", alerttext[1],
dpeName + ":_alert_hdl.2._text", alerttext[2],
dpeName + ":_alert_hdl.3._text", alerttext[3],
dpeName + ":_alert_hdl.4._text", alerttext[4],
dpeName + ":_alert_hdl.1._class", alertclass[1],
dpeName + ":_alert_hdl.2._class", alertclass[2],
dpeName + ":_alert_hdl.3._class", alertclass[3],
dpeName + ":_alert_hdl.4._class", alertclass[4],
dpeName + ":_alert_hdl.1._match", limits[1],
dpeName + ":_alert_hdl.2._match", limits[2],
dpeName + ":_alert_hdl.3._match", limits[3],
dpeName + ":_alert_hdl.4._match", limits[4],
dpeName + ":_alert_hdl.._active", TRUE);
err = getLastError();
if(dynlen(err)>0)
DebugTN("Error " + err + " adding alert for " + dpeName);
AMRPatricio
Post by AMRPatricio »
Hi All,
I am trying to do something similar but I am having the following warning:
WCCOAui (1), 2018.06.04 18:34:07.391, PARAM,WARNING, 31, Config type change failed, DP: System1:TestDP_1.element:_alert_hdl.._type, MAN: (SYS: 1 Ui -num 1 CONN: 1)
I am trying to change via script the "limits" associated with a alert_config that is already created. Do I need to delete the config and create it again or it is enough if I disable the config and then put it as active again after the change is done?
Any help?
Thanks,
Antonio
adaneau
Post by adaneau »
If you want to change an alert hdl settings, you need first to ack all instances of alarms for this config, then deactivate . change and reactivate.
Also be aware that changing from continuous to discrete will also implies that all parameters must be changed accordingly
Alex
