Oracle 12.2
12 posts • Page 1 of 2
sanikval
Oracle 12.2
Post by sanikval »
does WinCC OA (3.14, 3.15) support Oracle Server 12.2?
Andorhal
Re: Oracle 12.2
Post by Andorhal »
Hello.
Not yet.
Supported Versions can be found in detail within the documentation:
qthelp://wincc_oa/doc/RDB/RDB-20.htm
BR Robert
Re: Oracle 12.2
Oracle Server 12.2 support is planned for 3.16?
Re: Oracle 12.2
According to the information from our test team the following versions are supported with WinCC OA 3.16
Oracle Server 12.2.0.2
Oracle Client 12.2.0.1 / 12.2.0.2
nedzad
Re: Oracle 12.2
Post by nedzad »
Is it possible to connect Oracle Client 12.1.0.2.0 with the Oracle Database 11g Release 11.2.0.1.0 on WinCC OA 3.16 P03? I am trying to do it, but every time when I try to start RDB Archive Manager, I get the following messages in log:
WCCOArdb (97), 2018.10.10 15:46:15.179, SYS, INFO, 61, Cannot open file, Oracle Client Version 12 failed to load, try to load Oracle Client Version 11
WCCOArdb (97), 2018.10.10 15:46:15.179, SYS, FATAL, 2, Manager Stop, OCCI loading error. Check the Oracle Client! Could not load Version 11
WCCOArdb (97), 2018.10.10 15:46:15.179, SYS, FATAL, 2, Manager Stop, OCCI loading error. Check the Oracle Client Version and the config entry "oracleClientVersion"!
I can connect to database with the Oracle Client 12.1.0.1.0 on the other server.
Best Regards,
Nedžad Agi?
Re: Oracle 12.2
set in config file the following option:
[ValueArchiveRDB]
oracleClientVersion = 12
mkerk
Re: Oracle 12.2
Post by mkerk »
Please note that Oracle Database 11g Release 11.2.0.1.0 server is NOT supported in WinCC OA 3.16 P03.
Please upgrade your database to 12.2.02 version.
BR,
Mousser
nedzad
Re: Oracle 12.2
Post by nedzad »
Thanks a lot.
Best Regards,
Nedžad
giorgiob
Re: Oracle 12.2
Post by giorgiob »
Hi all,
I want to try WinCC-OA 3.14 RDBManager with Oracle, but I only can install express edition.
Does WinCC-OA 3.14 support Oracle XE release 11.2.0.2.0 (11gR2) ?
Thanks a lot.
giorgiob
Re: Oracle 12.2
Post by giorgiob »
I made the try.
The main problem is that in XE java isn't available, so i tried with use_java = 'no' and edited listener.ora to link external C-DLL.
The schema was created, but some errors resulted (see attached log).
Could you help me?
Thanks.
