Recently my server restarted and since its BIOS time was two hours in future in regard to a system time, some datapoint values were set with source time that corresponds to BIOS time. After that, server could not read any values from PLCs for the next two hours and I was getting this error message in log. I am wondering if there is any way to overwrite this source time, so that server can continue to read values normally?
I read this article: https://portal.etm.at/index.php?view=it ... &Itemid=54 , but this is different kind of problem.
I tried to set the .._original.._stime parameter manually, but it is read-only. Any suggestions?
Nedžad
Source time outside valid limits
Re: Source time outside valid limits
In WinCC OA the time information for a dp element must be in ascending order. Writing an original value with a time stamp older then the currently saved is not possible.
One possibility to set back the time stamps for the original value is to make an initialization of the "lastval" database, see link to FAQ section:
Please be aware that even if the original values are corrected you will have entries in the history (alarms, events) and alarm information with the wrong time information.
Probably you will get log messages after the correction of the original values which refer to inconsistent time information, especially for alerts.
