Moving objects in 3.15 p10
sp3k
Post by sp3k »
Hi, when I try to change the position of objects in a loop they sometimes disappear. The same script that works on 3.14 does not work on 3.15.
Please try the xml.
https://1drv.ms/u/s!AjlDI7Q-5T2PgclF72Mabq2YpuVvEQ
Re: Moving objects in 3.15 p10
I could not find the attached xml file.
Have you used a layout in the panel where position of the objects is changed?
sp3k
Post by sp3k »
added a link
xml
At my machine the objects also disappear sometimes with 3.16. I have changed the panel a bit, so the code can be stopped. And then I am able to see that without code running the disappeared objects becomes visible again after a redraw (by restoring after a minimize or changing the zoom level).
I would recommend to get in contact with the your WinCC OA support and submit a service request using Siemens NL support site, Siemens NL support mail or +31 70 333 3555.
schneebergera
Post by schneebergera »
I want to inform you that there was a correction according this "faulty behavior".
The correction will be delivered within the next summary patch (WinCC OA 3.15; WinCC OA 3.16).
best regards,
schneebergera
solved: new patch WinCC OA 3.15 P013 is available in download section.
best regards,
