Write to a file
11 posts • Page 1 of 2
MrKintaro
Write to a file
Post by MrKintaro »
hi,
can someone explain me how to open a file and add at the beginning of the file a string without overwrite what there is in the file?
main()
  int i, tell;
  string path;
  file f; // our file
  int err; // error code
  dyn_float value;
value[1]=12.123;
value[2]=8.0;
value[3]=3.1;
  path = getPath(SCRIPTS_REL_PATH);
  DebugN(path);
  //dyn_string s=getFileNames(path, "*",FILTER_DIRS);
  dyn_string s=getFileNames(path, "SetDescription.ctl",FILTER_FILES);
  for(i=1; i
Re: Write to a file
you can't INSERT something into a file.
What you have to do in this case is to:
1) write the new content into a new file
2) read the whole old content and append it to the new file
3) remove the old file
4) rename the new to the old file
MrKintaro
Re: Write to a file
Post by MrKintaro »
Hi Martin,
fileToString maybe an option.
do you know the limit of fileToString?
how big can be the string where I write the file?
MrKintaro
Re: Write to a file
Post by MrKintaro »
My point is becase I am searching a way how to encrypt the full Project but I have to insert the key in every file.
Re: Write to a file
The limit is RAM
Re: Write to a file
Can you please describe which part of the project you want to encrypt.
Encrypting the full project is not possible by adding information to files, e.g. the database files cannot be modified by adding some text.
MrKintaro
Re: Write to a file
Post by MrKintaro »
It seems very easy task but I am getting some trouble.
I want to encrypt our library that has a deep structure:
I have to loop through all the script in all folder and subfolder, but I am not finding a way to do it recursively and add the string // $License: NOLICENSE.
it seems a stupid function but I not able to loop tought the structure in a easy way.
To add the string I found the function.
RudiKreiner
Re: Write to a file
Post by RudiKreiner »
Have a look at the functions getFileNames() and isfile() in WinCC Help.
If you use getFileNames() recursively on all directories found you should easily be able to work you way through your whole file structure.
Re: Write to a file
I've written a function which creates a list of panel files (including all sub folders) for a given path.
The code for the function I have copied to the posting, the result is written to the global variable ds_panelFilesRecursive:
dyn_string ds_panelFilesRecursive;
getFiles(string s_path)
dyn_string ds_panelFiles;
int i;
DebugTN(__LINE__,"call getFileNames",s_path);
ds_panelFiles = getFileNames(s_path,"*",FILTER_FILES | FILTER_DIRS);
DebugTN(__LINE__,"result of getFileNames",ds_panelFiles);
for(i=1;i
Re: Write to a file
Just use the function 'getYoungerFiles' with as 'startTime' the value 0.
