Generating a multi-bit signal
Nikolay
Post by Nikolay »
Dear colleagues. Two single-bit signals come from the controller, one signal is generated on the side of the system's skada, depending on the state of these two signals. The implementation of this function should occur directly in para. Can we help Power config "_dp_fct"? Or is there another elegant solution?
Re: Generating a multi-bit signal
Yes, in this case you can use a datapoint function. It is the easiest solution.
