Free address powerconfig
Kirvesmies
Post by Kirvesmies »
Hi
1. PARA > Configure' _address' parameters. Using powerconfig 'free address' on _mp does not enable changing connection, driver number, in/out type, subscription.. Right?
2. Changing power config from 'free address' to S7Plus input did not work on master datapoint, bug? I had to delete master datapoint and re-create.
3. Is it supposed to work that you can generate a DPT with "SysMgm>Database>Archive compression", then edit DPT in PARA, then re-edit in "Archive compression"?
using v3.15p010
Kirvesmies
Re: Free address powerconfig
4. Exported DPT's with the _address PowerConfig set to for instance Simatic input, will at ASCII import in a new project be changed to free address. Why can't it stay set to Simatic Input?
Changing free address -> Simatic input is not possible directly, you have to first delete some other powerconfigs that are related to the Simatic input type.
