User not found warning
7 posts • Page 1 of 1
AMRPatricio
Post by AMRPatricio »
Hi all,
I am having the following warning on the log file:
"0, User not found: User2 login at System1:_UI_2"...
Apart of the warning it logs in with success with user 2.
Antonio Patricio
AMRPatricio
Re: User not found warning
I forgot to mention that only happens when bit level 32 is active on the workstation permissions.
Antonio
Can you please copy the complete log message into your posting. Then the complete information can be seen.
AMRPatricio
Hi Leopold,
Thank you for replay.
Here is the log file information:
WCCILpmon (1), 2018.05.15 13:15:25.100, SYS, INFO, 1, Manager Start, C:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAui.exe -PROJ Modbus_AP -pmonIndex 14 -p vision/login.pnl
WCCOAui (0), 2018.05.15 13:15:25.225, SYS, INFO, 1, Manager Start, PROJ, Modbus_AP, V 3.15 - 3.15 platform Windows AMD64 linked at Nov 23 2017 10:13:57
WCCOAui (0), 2018.05.15 13:15:25.251, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAui (0), 2018.05.15 13:15:25.257, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ ::1 (::1)
WCCILdata (0), 2018.05.15 13:15:25.270, SYS, INFO, 4, Connected to (SYS: 1 Ui -num 2 CONN: 1) @ ::1 (::1)
WCCILdata (0), 2018.05.15 13:15:25.291, SYS, INFO, 0, , Manager (SYS: 1 Ui -num 2 CONN: 1) initialised
WCCOAui (2), 2018.05.15 13:15:25.297, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAui (2), 2018.05.15 13:15:25.306, SYS, INFO, 3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOAui (2), 2018.05.15 13:15:25.316, SYS, INFO, 4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ ::1 (::1)
WCCILevent (0), 2018.05.15 13:15:25.342, SYS, INFO, 4, Connected to (SYS: 1 Ui -num 2 CONN: 1) @ ::1 (::1)
WCCOAui (2), 2018.05.15 13:15:25.347, SYS, INFO, 102, Waiting for user names/passwords
WCCOAui (2), 2018.05.15 13:15:25.356, SYS, INFO, 103, User names/passwords initialized
WCCOActrl (2), 2018.05.15 13:15:30.096, CTRL, WARNING, 0, , User not found: User2 login at System1:_Ui_2
Even with the warning the UI logged in with User 2 automatically.
Antonio
Are you using "Windows User Administration" in this project?
Which CTRL script is started with CTRL manager number 2?
It looks like the log message is related to a function defined in the CTRL script updateUserGroups.ctl.
AMRPatricio
Yes, I am (trying) to use "Windows User Administration". CTRL manager nr 2 is running the updateUserGroups.ctl system script
Antonio
Is the CTRL manager with number 2 only running this script?
Normally this script is part of the script list pvss_scripts.lst.
Can you please check if the script is running only once in your project.
Senior Support Specialst
