in version v3.16, when using function
httpGetHeader(int idxm, string key)
like
"string cookie = httpGetHeader(connIdx, "Cookie");"
connIdx is int
I get warning
Invalid argument in function, ..., httpGetHeader
Is there solution for this warning?
httpGetHeader() invalid argument v3.16
- kilianvp
Re: httpGetHeader() invalid argument v3.16
this means your browser dont send a Cookie HTTP Header
just see add a
inside your callback to see all Headers
the 3.16 help example has the same problem:
//edit GET wont work.. POST works
Content-Type is a HTTP Header sent by the Server not the client.
appears in the Logviewer
just see add a
DebugN(headernames);the 3.16 help example has the same problem:
#uses "CtrlHTTP"
int MAXLENGTH = 100 * 1024 * 1024; //100 MB
main()
//starts the HTTP Server at Port 12000 without authentication
httpServer(FALSE,12000);
httpSetMaxContentLength(MAXLENGTH);
/* Use http://localhost:12000/callBack1 URL in order to show the data */
/* httpConnect registers the function "callBack1" as a Web resource under the name "callBack1" */
httpConnect("callBack1","/callBack1");
//See rfc1867 for detailed information on form-based file uploads in HTML
string callBack1(blob content, string user, string ip, dyn_string headernames, dyn_string headervalues, int connIdx)
string formDoc = "Test" +
"Example page" +
string contentType = httpGetHeader(connIdx, "Content-Type"); //Returns the value of the header
DebugN("Content type:",contentType);
return formDoc; //Returns the form
}and the warningWCCOActrl2:2018.05.10 11:29:32.215[dyn_string 10 items
WCCOActrl2: 1: "Host"
WCCOActrl2: 2: "Connection"
WCCOActrl2: 3: "Cache-Control"
WCCOActrl2: 4: "Upgrade-Insecure-Requests"
WCCOActrl2: 5: "User-Agent"
WCCOActrl2: 6: "Accept"
WCCOActrl2: 7: "DNT"
WCCOActrl2: 8: "Accept-Encoding"
WCCOActrl2: 9: "Accept-Language"
WCCOActrl2: 10: "Cookie"
WCCOActrl2:]
- vedadramovic
Thank you Kilian,
this warning is not present in earlier versions.
What does httpGetAllHeaders() return?
If this also produces a warning than the specified 'connIdx' is wrong.
You should use the connection index value that is returned as argument in the callback function after the 'headerValues'.
Otherwise this header is not available and apparently since 3.16 that results also in this 'invalid argument' warning.
So the only way to prevent the warning is to check first if the client has actually passed the header.
- vedadramovic
httpGetAllHeaders() returns:
WCCOActrl106:2018.05.25 14:15:04.804[mapping 4 items
WCCOActrl106: "User-Agent" : "Apache XML RPC 3.0 (Jakarta Commons httpclient Transport)"
WCCOActrl106: "Content-Length" : "210"
WCCOActrl106: "Content-Type" : "text/xml"
WCCOActrl106: "Host" : "127.0.0.1:8002"
This header "Cookie" is not present.
I think it would be easier if warning was not issued if the header is not present (like in previous versions), rather than checking if it is present.
This way logs are clogged with this warning.
