the default ECDHCurve prime256v1 is insecure!
you should use at least secp384r1 as default ECDHCurve!
I tried to change the CipherSuiteList to something modern using:
https://mozilla.github.io/server-side-t ... generator/
https://testssl.sh/openssl-rfc.mapping.html
CipherSuiteList = "ECDHE-ECDSA-AES256-GCM-SHA384,ECDHE-RSA-AES256-GCM-SHA384,ECDHE-ECDSA-CHACHA20-POLY1305,ECDHE-RSA-CHACHA20-POLY1305,ECDHE-ECDSA-AES128-GCM-SHA256,ECDHE-RSA-AES128-GCM-SHA256,ECDHE-ECDSA-AES256-SHA384,ECDHE-RSA-AES256-SHA384,ECDHE-ECDSA-AES128-SHA256,ECDHE-RSA-AES128-SHA256"than i tried:
CipherSuiteList = "ECDHE-ECDSA-CHACHA20-POLY1305,ECDHE-RSA-CHACHA20-POLY1305,ECDHE-ECDSA-AES128-GCM-SHA256,ECDHE-RSA-AES128-GCM-SHA256,ECDHE-ECDSA-AES256-GCM-SHA384,ECDHE-RSA-AES256-GCM-SHA384,DHE-RSA-AES128-GCM-SHA256,DHE-RSA-AES256-GCM-SHA384,ECDHE-ECDSA-AES128-SHA256,ECDHE-RSA-AES128-SHA256,ECDHE-ECDSA-AES128-SHA,ECDHE-RSA-AES256-SHA384,ECDHE-RSA-AES128-SHA,ECDHE-ECDSA-AES256-SHA384,ECDHE-ECDSA-AES256-SHA,ECDHE-RSA-AES256-SHA,DHE-RSA-AES128-SHA256,DHE-RSA-AES128-SHA,DHE-RSA-AES256-SHA256,DHE-RSA-AES256-SHA,ECDHE-ECDSA-DES-CBC3-SHA,ECDHE-RSA-DES-CBC3-SHA,EDH-RSA-DES-CBC3-SHA,AES128-GCM-SHA256,AES256-GCM-SHA384,AES128-SHA256,AES256-SHA256,AES128-SHA,AES256-SHA,DES-CBC3-SHA"The connection to this site uses TLS 1.2 (a strong protocol), RSA (an obsolete key exchange), and AES_128_GCM (a strong cipher).
even the example from the WinCC OA help:
cipherSuiteList = "DHE-RSA-AES256-SHA256,DHE-RSA-AES256-GCM-SHA384"
