passing string to $ sign from scripts
ray78
Post by ray78 »
Hi there,
I am trying to display the comments of data points (defined as DPE description in Common tab) in a new screen. below is my code:
void MIL_NavigateToPage(string sSiteNo, string sSiteType)
string sVal1;
string sText1;
sVal1 = "$dpe_value1:System1:"+sSiteNo+""+sSiteType+"-Status.BURST_STATUS";
sText1 = dpGetComment("System1:42045.FlumeGate-R-Status.CTRL_SUSPENDED");
DebugN("first text:",sText1);
sText1 = "$dpe_Text1:"+sText1;
DebugN("second text:",sText1);
DebugN("value :",sVal1);
RootPanelOn("MIL_Panels/MIL_DEVICES/FlumeGateR/FlumeGateR_Overview.pnl",
makeDynString(sVal1,sText1,"$dpe_value2:System1:42045.FlumeGate-R-Status.CTRL_SUSPENDED"));
The sVal1 value is shown on the page with no problem but the text is not showing, looking at the log viewer below will see the assignment. The $dpe_value1 has the data point name in there but for $dpe_Text1 I couldn't use the dataoint instead I used the string variable I had built from the dpGetComment looks like the assignment is not done correctly because text doesn't appear on the screen. Whats is the right syntax to assign a string to a $ value?
WCCOAui1:["first text:"]["42045 Control Suspended"]
WCCOAui1:["second text:"]["$dpe_Text1:42045 Control Suspended"]
WCCOAui1:["value :"]["$dpe_value1:System1:42045.FlumeGate-R-Status.BURST_STATUS"]
Re: passing string to $ sign from scripts
The Debug messages are written before opening the panel using RootPanelOn(). Therefore I cannot see if passing the parameters to the panel worked or not.
How did you check that the $-parameters do not have the correct values in the panel MIL_Panels/MIL_DEVICES/FlumeGateR/FlumeGateR_Overview.pnl?
Info: If you are not using a distributed system or if you want to read data for the own system (in a distributed system) there is no need to use the system name in any function referring to data point elements.
ray78
Post by ray78 »
Hi Leopold,
I don't know exactly how I can use DebugN to see if the parameters are assigned to the panel correctly. Can you advise what Debug syntax I should use for that?
I know the assignment didn't work because it is not appearing in the panel. So I used DebugN to see what parameters are passed to the RootPanelOn function. I understand how to assign data points and that's how I built sVal1 but in the panel there are texts which I also like to assign them in this script so I built sText1 but this contains string and when I assign the string to the $dpe_Text1 parameter in my script it has the following format: "$dpe_Text1:42045 Control Suspended".
My question is how do I pass a string or a comment (42045 Control Suspended) to the parameter ($dpe_Text1) looks like the format is not correct maybe there is another syntax to assign the strings.
This is a distributed system that;s why I am using the System1 name.
I attached the copy of the project the code is in the click section of Overview Panel. https://www.winccoa.com/fileadmin/image ... MASTER.zip
MIL_MASTER.zip
(3.05 MiB) Downloaded 174 times
The syntax looks like it is okay for passing a $-parameter.
In the panel which is opened you can simply do a DebugN($parameter); (e.g. in the Initialize event of the panel) to see which values was assigned to a $-parameter.
ray78
Post by ray78 »
I found that the $Parameter I used in the child panel had a duplicate name in another child panel and that confused the assignment. Once I changed the name of $parameter to something else it started working.
