Archive smoothing
- Kirvesmies
Archive smoothing
Question on archiving smoothing powerconfig. Driver side smoothing can be configured so that different DP's have different smoothing but for archiving there seems to be that all DP's get the same setting as the master datapoint. Correct?
- tmalone
Re: Archive smoothing
That is correct, the concept of a master datapoint is to create a template for all instance to follow.
The smoothing parameters are not exposed to be edited
This can be changed, but the solution is a bit too complex for this discussion.
Use the ASCII manager and do an export on that DPT, and that DP, and choose archive. You should see the smoothing values and update them. Import using ASCII Manager when done. See help for more info on ASCII Manager.
HINT: with ASCII manager, be careful not to export the whole project. At least pick a DataPoint Type in the upper right box.
Todd
Todd
