Gedi issue
Gedi issue
I noticed some issues that makes the developer life unnecessary painfull/hard when it comes to working the Gedi
its not possible to copy objects between two gedi instances (Copy/Paste)
you can't undo: (ctrl+ z)
changes in objects atributes
changes in panels sizes
you can't abort: (by pressing Esc)
schneebergera
Re: Gedi issue
Post by schneebergera »
What is the use-case to have more than one GEDI running? In general only a UI like a graphical object editor runs on a machine to style the panels.
It is therefore a separate UI instance (per design) in which the copying of objects to another instance is not possible.
It is possible to "undo" changes in objects attributes (one step back). If you enter the panel size via the attributes it is also possible to change the panel size back. "Esc" is not configured, yet.
best regards,
