Interface documentation for OaAuthUser
fleitner
Post by fleitner »
I'm currently trying to implement a user defined authentication for WinCC OA. The documentation describes to implement an OaAuthMethodUserdefined class
For the custom password verification, the user is given as an OaAuthUser object. However, I can not find the interface description for that class, the corresponding control script is encrypted and the help does not contain any information about it.
As such I can not extract the username from that object and without username the password check is difficult.
I can output the object with DebugN, which results in
WCCOAui2:["user: name:asd | domain:AD1 | lang:en_US.utf8 | ID:65535 | auth:authType:2 | factory:methods::OaAuthMethod OaAuthMethodUserdefined::create() | Windows:OaAuthMethod OaAuthMethodAD::create() | Standard:OaAuthMethod OaAuthMethodStandard::create() | ws:"]
Can anyone give me a hint on how to access that object, or where to find the corresponding documentation?
I tried accessing it as an array, but to no avail.
Best regards
Frank
Re: Interface documentation for OaAuthUser
The script editor auto completion should show you which functions are available.
But to get the user name you can use the 'getName' function from the 'OaAuthUser' object.
fleitner
Post by fleitner »
Thank you for your answer. I can't get the auto completion to work in the script editor, but the getName function works fine.
Best regards
Frank
