RDB connected error on WINCC OA start
BenjaminSeeker
Post by BenjaminSeeker »
when I finish My RDB Setting then start my wincc oa project.
Including the configuration of environment variable, the configuration on config file of wincc oa and the configuration of RDB in GEDI.
but I can not start my RDB manager successfully.
FYI, My dongle have RDB license.
My computer: vmware workstation v8.0
Wincc OA Version:3.11 x64
OS:Windows Server 2008 R2 x64 enterprise
Oracle version:win64_11gR2_database_1of2 11.2.0.1.0
the wincc oa and the oracle on the same computer.
When my console try to strart the RDB manager, It showed a dialog.
Then text of the dialog is "Can not locate program input point OCIPHeapAllocUc on OCI.dll".
and here is the text on LogViewer.
WCCILpmon (1), 2012.10.29 00:23:25.383, SYS, INFO, 1, Manager Start, C:\\Siemens\\Automation\\WinCC_OA\\3.11\\bin\\WCCOArdb.exe -PROJ QDHP_Sire -pmonIndex 2 -num 99
WCCOArdb (99), 2012.10.29 00:23:25.548, SYS, INFO, 0, , The Manager is using the Archive Groups in the Database!
WCCOArdb (97), 2012.10.29 00:23:25.550, SYS, INFO, 1, Manager Start, PROJ, QDHP_Sire, V 3.11 - 3.11 linked at Jul 11 2012 22:13:13
WCCOArdb (97), 2012.10.29 00:23:25.644, SYS, INFO, 3, Trying to connect to, (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOArdb (97), 2012.10.29 00:23:25.663, SYS, INFO, 4, Connected to, (SYS: 0 Data -num 0 CONN: 1) @ benServer08R264 (127.0.0.1)
WCCILdata (0), 2012.10.29 00:23:25.719, SYS, INFO, 4, Connected to, (SYS: 4 Data -num 99 CONN: 1) @ benServer08R264 (::ffff:127.0.0.1)
WCCILdata (0), 2012.10.29 00:23:25.783, SYS, INFO, 0, , Manager (SYS: 4 Data -num 99 CONN: 1) initialised
WCCILdata (0), 2012.10.29 00:23:25.786, PARAM,INFO, 1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 97
WCCOArdb (97), 2012.10.29 00:23:25.862, SYS, INFO, 0, , Internal Dp Value changed! It will take a few seconds that the Manager uses the Value changes.
WCCOArdb (97), 2012.10.29 00:23:25.862, SYS, INFO, 0, , Internal DP stopWriteToDB is false
WCCOArdb (97), 2012.10.29 00:23:29.731, SYS, INFO, 61, Cannot open file, Oracle Client Version 11 failed to load "oraocci11", try to load Oracle Client Version 10
WCCOArdb (97), 2012.10.29 00:23:29.731, SYS, FATAL, 2, Manager Stop, OCCI loading error. Check the Oracle Client! Could not load Version 10
WCCOArdb (97), 2012.10.29 00:23:31.734, SYS, INFO, 181, Closing connection to (SYS: 4 Data -num 0 CONN: 1)
WCCILdata (0), 2012.10.29 00:23:31.735, SYS, INFO, 39, Connection lost, MAN: (SYS: 4 Data -num 99 CONN: 1), Connection closed
WCCILdata (0), 2012.10.29 00:23:31.735, SYS, WARNING, 65, Wrong destination address, (SYS: 4 Event -num 0 CONN: 1), DP_MSG_COMPLEX_VC
WCCILdata (0), 2012.10.29 00:23:31.736, PARAM,INFO, 2, Manager Stop, HistOrgMain, archive is now offline, archive number is:97
WCCOArdb (97), 2012.10.29 00:23:31.736, SYS, INFO, 39, Connection lost, MAN: (SYS: 4 Data -num 0 CONN: 1), Connection closed
WCCOArdb (97), 2012.10.29 00:23:31.737, SYS, SEVERE, 2, Manager Stop, Lost connection to the Data Manager! RDB will shut down.
WCCOArdb (97), 2012.10.29 00:23:31.757, SYS, INFO, 0, , Closing the connections to the Data Base! This may take some time - please wait for final shutdown message.
WCCOArdb (97), 2012.10.29 00:23:33.155, SYS, INFO, 61, Cannot open file, Oracle Client Version 11 failed to load "oraocci11", try to load Oracle Client Version 10
WCCOArdb (97), 2012.10.29 00:23:33.157, SYS, FATAL, 2, Manager Stop, OCCI loading error. Check the Oracle Client! Could not load Version 10
WCCOArdb (97), 2012.10.29 00:23:33.158, SYS, FATAL, 2, Manager Stop, OCCI loading error. Check the Oracle Client Version and the config entry "oracleClientVersion"!
WCCOArdb (97), 2012.10.29 00:23:33.192, SYS, INFO, 0, , Closing the Data Base connections is finished!
WCCOArdb (97), 2012.10.29 00:23:33.194, SYS, INFO, 2, Manager Stop
Re: RDB connected error on WINCC OA start
at the WinCC OA online help it is described that you need Oracle 11.2.0.2.0 or a newer version.
Maybe this is the problem why it does not work at your computer.
Please install the required version.
If the problem still occurs please send the problem description to the official support address support.automation@siemens.com including all the necessary information:
https://portal.etm.at/index.php?option= ... &Itemid=54
aorange
Post by aorange »
We use that version of Oracle (11.2.0.1.0) with WinCC-OA 3.10 SP2, I guess it may not be compatible with 3.11
What does your RDB_config.sql file look like?
BenjaminSeeker
define connect_identifier = 'orcl'
define sysdba_user = 'SYSTEM'
define yesno_newuser = 'yes'
define schema_user = 'PVSSRDB'
define app_user = 'PVSSAPP'
define use_rman = 'os'
define os_sys = 'win'
define zip_backup = 'yes'
define sequence_start = 100000
define sequence_maxvalue = 199999
define path_dbfile = 'C:\\oracle\\oradata\\DB\\PVSSRDB\\'
define path_tempdbfile = 'C:\\oracle\\oradata\\DB\\PVSSRDB\\temp\\'
define path_oraclebin = 'C:\\app\\Administrator\\product\\11.1.0\\db_1\\bin\\'
define instance_name = 'orcl'
define host_name = 'ServerPVSS'
define path_backup = 'C:\\oracle\\oradata\\DB\\PVSSRDB\\backup\\'
define path_alert = 'C:\\oracle\\oradata\\DB\\PVSSRDB\\alert\\'
define path_event = 'C:\\oracle\\oradata\\DB\\PVSSRDB\\event\\'
define mytimezone = 'Asia/Shanghai'
define asm_instance = '+ASM'
define service_name = 'orcl'
define number_db_storage = 1
BenjaminSeeker
sorry! this is the right one.
define sysdba_user = 'system'
define path_dbfile = 'C:\\oracle\\oradata\\DUMMY_DB\\PVSSRDB\\'
define path_tempdbfile = 'C:\\oracle\\oradata\\DUMMY_DB\\PVSSRDB\\temp\\'
define path_oraclebin = 'C:\\app\\benServer2008R2\\product\\11.2.0\\dbhome_1\\BIN\\'
define host_name = 'benServer08R264'
define path_backup = 'C:\\oracle\\oradata\\DUMMY_DB\\PVSSRDB\\backup\\'
define path_alert = 'C:\\oracle\\oradata\\DUMMY_DB\\PVSSRDB\\alert\\'
define path_event = 'C:\\oracle\\oradata\\DUMMY_DB\\PVSSRDB\\event\\'
define asm_instance = 'ASMSID1'
BenjaminSeeker
OK, I change oracle version from 11.2.0.1.0 to 11.2.0.3.0.
Problem Solved!
Thanks!
