Deregistering subproject
riso77
Post by riso77 »
Is there a way to deregister a subproject and register it once again correctly?
Now when I integrate a subproject into a project I get an error message that the path does not exist.
There exists a workaround to solve this: I rename the subroject folder, register it, integrate in the project and then it works.
But I would like to know the "clean" way, so that I do not have to rename the subproject folder name.
thanks for help
adaneau
Re: Deregistering subproject
Post by adaneau »
Just delete it from your project config file and it will not be used anymore
Alexandre
riso77
Post by riso77 »
But removing the subprojects' path from the projects' config file does not remove the Subproject from the Subprojects table.
adaneau
Post by adaneau »
Ah if you just want to unregister it, click the trash can on top of project management and delete it from list :)
schneebergera
Post by schneebergera »
but it should. Is it possible to remove the subproject directly via the panel (project_admin_sub.pnl)
Please tell me your used WinCCOA version, incl. patchhlevel.
Pleases check the entries in the registration file.
[C:\\ProgramData\\Siemens\\WinCC_OA\\pvssInst.conf]
best regards,
riso77
Post by riso77 »
Hello Andreas,
my WinccOA is 3.15 P006
Yes, you were right, removing the entries from the [C:\\ProgramData\\Siemens\\WinCC_OA\\pvssInst.conf] made the subproject RCM dissapear from the project_admin_sub.pnl panel.
The subproject is listed only in project_admin_sub.pnl and not in the project_admin.pnl, but there is no trash can button to remove/deregister the subproject from the project_admin_sub.pnl panel. Image
