Variable trend unexpectedly autoscales
Piterskiy
Post by Piterskiy »
I have a problem with Variable Trend on v.3.14 p10 when using open time range and curve with autoscaling.
Each time when clicking on the trend at first time - ruler appears, the second time - it goes and value autoscaling (on the Y-axis) performs, this autoscaling looks unexpected. Could it be turned off?
On v.3.15 p7 - works good without any autoscaling
schneebergera
Re: Variable trend unexpectedly autoscales
Post by schneebergera »
in version 3.14 the var.-trend auto-scales after zooming and disabling the ruler. There is no possibility to turn it off, because it is by design. On Trend-Widget it is possible to turn off "auto-scaling" at all.
The behavior is intentional because if "auto-scaling" is enabled in "play mode", it should work as specified. When someone activates a ruler, the trend is in "stop-mode", so you can check the values well.
Removing the last ruler returns to the "play-mode", resuming the original "auto-scaling" setting. This makes it clear that all curves are completely visible during "auto-scaling". Within 3.15 the behavior has been changed due new features.
best regards,
Piterskiy
Post by Piterskiy »
Thank you, Andreas.
