ifDollarDefined() and RootPanelOnModule generates Warnings
7 posts • Page 1 of 1
moto3101
Post by moto3101 »
Hello together,
In the init of the panel, we are using ifDollarDefined("$foo"), still we are getting warnings about missing $ parameters when loading this panel in a module.
I just wanted to know if there is a way to prevent WinCC OA from generating these warnings when loading panels on modules without providing the respective dollar parameters in the rootPanelOnModule method.
Thanks and with best regards,
moTo
fmulder
Re: ifDollarDefined() and RootPanelOnModule generates Warnings
Post by fmulder »
You probably have something like this in your code:
string strFoo = $foo;
I've also seen messages like you say when you define the variable as a panel global variable in your Scopelib.
* Do not define the variable with the $ in your scopelib
* Define the variable in your EventInitialize (with or without isDollarDefined)
The better way to do this is, which will keep away the error message is:
string strFoo;
if( isDollarDefined( "$Foo" ))
  strFoo = $Foo;
p.s.
I often use this trick to test my panels. When I make an icon then I make sure that it runs with a dollar code or without a dollar code.
Example:
string strDatapoint = "MYVALVE";  // Use a default datapoint for testing
// This icon can be used with or without the dollar code
if( isDollarDefined( "$datapoint" ))
  strDatapoint = $Datapoint;
Hope this helps
share the fun
Frenk Mulder
moto3101
Post by moto3101 »
Hello Frenk,
thanks for your reply.
No we don't, that's the thing that confuses me. We are defining the variable in the scope lib:
string strDatapoint = "";
and in the init we have
if( isDollarDefined( "$dp" ))
  strDatapoint = $dp;
Still, when loading a panel in a module without providing the dp parameters we get the error.
RootPanelOnModule("Folder/panel.pnl","Foo","BarModule",makeDynString();
CTRL, WARNING, 51, Parameter incorrect, did not find the $-parameter, $dp
PARAM,WARNING, 81, Syntax error, $-Parameter, Module: BarModule
If we are using
RootPanelOnModule("Folder/panel.pnl","Foo","BarModule",makeDynString($dp:);
the error vanishes.
Personally, I don't see the point in throwing errors if we are checking if the parameter is defined.
moTo
fmulder
Post by fmulder »
We do 'string strDP' in the scopelib.
We assign the dollar code in the EventInitialize.
Do not mention "$DP" in the scopelib.
We had the same issue. Our rule now is : no $ codes in the scopelib
Good luck
Frenk Mulder
moto3101
Post by moto3101 »
Hi Frenk,
its not in the scope lib. Its in the EventInitialize of the panel, as mentioned above.
moTo Image
Are we talking about an issue with $-parameters throwing warnings when using XML Panel files, which has been solved in 3.15 P8 ?
moto3101
Post by moto3101 »
Dear Martin,
we are using .pnl files. However, we are not using 3.15 but 3.14.
moTo
