Archive Manager 0
AMRPatricio
Archive Manager 0
Post by AMRPatricio »
Hi Guys,
Maybe someone can help: sadly my Archive Manager 0 did not start. Or better it starts for about 2seconds and then it stop. Never experienced that problem before and it was working last time I was working on the project. The only helpful information present on event log is:
WCCOAvalarch (0), 2018.03.23 10:52:27.271, SYS, INFO, 1, Manager Start, PROJ, NRLHMI, V 3.15 - 3.15 platform Windows AMD64 linked at Nov 7 2017 21:47:36
WCCOAvalarch (0), 2018.03.23 10:52:32.482, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (0), 2018.03.23 10:52:32.501, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1F0ACC.ad001.siemens.net (127.0.0.1)
WCCILdata (0), 2018.03.23 10:52:32.516, SYS, INFO, 4, Connected to (SYS: 1 Data -num 2 CONN: 1) @ MD1F0ACC.ad001.siemens.net (::ffff:127.0.0.1)
WCCILdata (0), 2018.03.23 10:52:32.531, PARAM,INFO, 1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 0
WCCILdata (0), 2018.03.23 10:52:32.537, SYS, INFO, 0, , Manager (SYS: 1 Data -num 2 CONN: 1) initialised
WCCOAvalarch0: .569[8632](ArHeapControl.cpp:965) Assertion '[dynLen > 0]' failed !! - dynLen=0
WCCOAvalarch0:ACE_ASSERT: time 03/23/2018 10.52.33.570000 file D:\\workspaces\\3.15\\workspace\\Exe\\DataNew\\ValueArchive\\ArHeapControl.cpp, line 965 assertion failed for 'dynLen > 0'.
WCCILdata (0), 2018.03.23 11:13:12.323, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Data -num 2 CONN: 1), Connection reset by peer (10054)
WCCILdata (0), 2018.03.23 11:13:12.342, PARAM,INFO, 2, Manager Stop, HistOrgMain, archive is now offline, archive number is:0
I am using the manager to archive some of my values.
Thanks in advance
Antonio
Re: Archive Manager 0
Maybe the archives files got corrupted (e.g. by stopping the project not properly) and therefore the manager cannot start.
You can try to delete the newest file AR_0000_ and then start the archive manager again. Please note that data saved in this file is lost then.
