Events Screen - Filter by Value
Ashraf.nsubuga
Post by Ashraf.nsubuga »
I have a system with boolean data type for my DPEs. In the Event screen, I want to only get events appearing when the value for a DPE changes from FALSE to TRUE. I don't want the User to see the FALSE events.
I've looked at the Event properties dialog but I'm struggling to implement this in the "Filter" tab.
Any one have a solution for this?
dschneid
Re: Events Screen - Filter by Value
Post by dschneid »
Extract the attached zip file and copy the files from folder "panel" and "script" into your project.
Set a config entry for [ui] section:
[ui]
LoadCtrlLibs = "HOOK_aes_modifyQuery.ctl"
If you open afterwards the Event Screen, you will get an additional tab in the properties panel of the AES screen.
Now you are able to extend the filter e.g. to show only values changes where e.g. the _original.._value is "TRUE".
Attention:
This is not a WinCC OA product standard. The usage of this functionality is not supported by ETM.
Br Dieter https://www.winccoa.com/fileadmin/image ... 180326.zip
EventScreenFiltering-20180326.zip
(5.83 KiB) Downloaded 215 times
Ashraf.nsubuga
Thank you!
