HistoryDB - archive backup
Ashraf.nsubuga
Post by Ashraf.nsubuga »
I am trying to set up an archive of Events which gets backed up when a pre-determined threshold of events is reached (e.g. 500).
I have added the “_archive” config to the DPE’s in my system as necessary but when I try to configure the target-path of where I want the backup to be stored I have struggled to get it to work.
Any ideas about the resolution?
Re: HistoryDB - archive backup
When configuring the backup for the value archives you have to define a target path and the time when the "old" archive files shall be copied to the backup device.
At which point of the configuration have you seen the problem?
Ashraf.nsubuga
Hi Leopold,
I have set the time and also configured a test location on my local directory. I also tried this on several machines. After the time of the backup passes I check the path where I expect the backup to be but it is empty. There is also nothing appearing in the log to suggest that the process was carried out at the proposed backup time.
I have also seen this message in the configuration screen before: "Not possible to initialize data media"
Ashraf.nsubuga
I finally managed to resolve the issue. The backup works fine now.
