I have realized some tests on the 3.15 version , creating a panel on which I have inserted
a Webview EWO.
The panel is correctly displayed with an UI desktop working on MS-Windows, but it's not working
on my smartphone (others EWO are correctly displayed). A simple text is displayed to inform
that the EWO was not loaded.
When I put the debug flag "HTTP" on the controller "http_webclient", it's seems there's a problem
during the loading of the EWO (reference to a path widgets\\android-arm\\webview.ewo)
Is there any limitation with this EWO? How can insert an HTML page?
I have separate my HMI with a naviModule, inserting some naviButtons. These are working correctly
on the first step (the panel associated to topology node is correctly displayed), but when I select again
these buttons it seems to be freezed!
regards
Emmanuel
WebClient is not loaded (UI desktop)
- agruber
Re: WebClient is not loaded (UI desktop)
The WebView EWO is not supported within the mobile UI.
However, that might change. We have a test version, but it suffers from some problems, thats why it is not released yet.
BR, Andreas
Customer Care
BR, Andreas
Customer Care
- eMichx
Hello Andreas,
We realized tests with WinCCOA in order to show it during the hackathon for Siemens Mobility France. Do you think it would be possible to get this version of
the EWO Webview for the show (beginning of April). This evolution will be available on th 3.15 version or upper?
regards
Emmanuel
regards
Emmanuel
- agruber
We will continue this discussion outside of the forum.
BR,
BR,
