After doing some changes in any of the libraries it is needed to reload the libraries in order to apply these new changes on the active UIs.
When I execute this option "Reload CTRL Libs" I have the feeling that it is a matter of luck if I have to change the picture I am using in the UI, stop the UI or even restart Gedi completely. I am sure there is a reason why, but I am not sure.
For sure it is needed to close the panel or applications which are using these libraries, but I have also situation for specific Libraries where I need always to close completely Gedi and start it again which makes the engineering a harder.
My actual assumption is that it has something to do with the global variables I am using in this code. Is it right? Which are clues to know in advance if I have to restart the UIs or Gedi completely?
Why different results for Gedi Option-> Reload CTRL Lib?
- alaralum
