Hi
Ia m developing an algorithm for changing the color of the lines of an electric diagram representation.
I have created a panel ref with the switches and the lines conecting them and a script to change the color of the lines using setValue.
The problem is that i group the lines in the panel ref and the setValue function does not change the color. for example:
- setValue("Ref1.LineA","color","Red") works perfectly
- setValue("Ref1.shapeGroupA", "color", "Red") does not work
if i create a group in the main panel it works well, but not inside the ref.
¿What could be the solution ?
Thank you very much
Change color of a shape group inside a ref
- adaneau
Re: Change color of a shape group inside a ref
If you use 3,15, you can probably build a public function or a property doing that in your ref and just call it from outside. See OOP in online help for more information
- jonred
i have taken a look, but i have to study it more.
is possible to create in the ref an event to detect the change of the color of a line and change some other color lines?
Somethinh like that?
- adaneau
I can see 2 solutions:
1)
In scope of ref:
#property color gCol
setGCol(string col)
setVMultiValue("LineA","color",col,"LineB","color",col,"LineC","color",col,...);
string getGCol()
return LineA.color;
In parent panel: ref1.gCol = "red";
2)
In scope of ref:
public void changeGroupColor(string col)
In parent panel: ref1.changeGroupColor("red");
1)
In scope of ref:
setGCol(string col)
string getGCol()
return LineA.color;
2)
In scope of ref:
- jonred
thank you for your answer, at the moment i'am with other topics, but i will try it when i can.
