Display Alarms with Ultralight
adaneau
Post by adaneau »
I have a question about Ultralight client. So I want to display my active alarms but the alert row (/alert screen) is not displayed with ultralight. Does anybody have a solution to avoid this?
Maybe making my own alarm screen with dpConnect and a table will be a way but not sure.
Edit: after looking more deeply into the help I find : "reinitAlarmListObject" function but I can't find the right parameter to use it
I use a rectangle shape, the internal datapoint _AESProperties_000x , and a dynstring which contains 3 columns (test 1,2 and 3). But I can't see anything in quick test module. Which of my parameters could be false?
Thanks in advance for your help.
Alexandre DANEAU
Re: Display Alarms with Ultralight
the _AESProperties-datapoints only contains the information which settings have to be used when displaying the AEScreenAESRow. These datapoints do not contain a list of dp-elementsalerts which can be displayed.
In our Ultralight-demoproject we are using the reference-panel "oibjects/STD_PANELSAESRow.pnl" to display the alerts. This panel is inserted as a reference into another panel which is then saved in xml-format.
Please check if this solution can also be used in your project.
If it does not work plrease refer to the common WinCC OA support for further assistance.
