I am using Modbus for reading and writing booleans. While reading is working fine, I have problems with writing. The error I get is :
WCCOAmod (1), 2018.03.02 08:52:35.505, PARAM,SEVERE, 54, Unexpected state, DP: (Type: 223 Sys: 1 Dp: 1204 El: 59 : _original.._value), MAN: (SYS: 1 Driver -num 1 CONN: 1),
Missing transformPtr for M.1.5.9840
The configuration is write single coils , type is set to boolean. The other PLC parameters are the same as reading boolean (single coils).
What am I doing wrong ?
Walter
Modbus TCP writing issue
- mkerk
Re: Modbus TCP writing issue
Could you please check again the configuration of the address-config. Your are using the Function code 5. for this you need the following:
1- The Type of the WinCC OA Datapointelement must be bit.
2- The type of Transformation in the address config must be “booleanas byte” and not “boolean”!
Please refer also to the WinCC OA documentation “Modbus/TCP driver ? Mdbus/TCP driver details ? Transformations” for detailed information about which transformations is compatible with which the function code.
BR,
Mousser
BR,
Mousser
